Configure CFM MD
Use this procedure to configure a Connectivity Fault Management (CFM) Maintenance Domain (MD). An MD is the part of a network that is controlled by a single administrator. A single MD can contain several Maintenance Associations (MA).
- Select CFM.
- Select the MD tab.
- Select Insert.
- In the fields provided, specify an index value, name, and level for the MD.
- Select Insert.
MD Field Descriptions
Use the data in the following table to use the MD tab.
Name |
Description |
Index |
Specifies a maintenance domain entry index. |
Name |
Specifies the MD name. |
NumOfMa |
Indicates the number of MAs that belong to this maintenance domain. |
Level |
Specifies the MD maintenance level. The default is 4. |
NumOfMip |
Indicates the number of MIPs that belong to this maintenance domain |
Type |
Indicates the type of domain. |
